huzzer
New Big End Bearings
huzzer
If the only thing that is new is the big end bearings, do i need to run them in? or are they just good to go?
Cheers,
Ben
They need to be run in, as they are the weakest point of the XU engine, If you;ve seen the one's I;ve seen or what remains you would see what I mean,
Just keep the rev's down for a least the first 500 miles
zowow
would prob still take it steady before you flog it :ph34r:
huzzer
Need to be run in by thursday :ph34r: , is it ok to do lots of miles in one go, without any cooling down in between or does it need to be short runs with complete cool down before another run?
Normski
I can't see any need to run in big end bearings. They float on oil so how does running in have any affect on them?
Beastie
Makes you wonder how on earth they (or the crank) ever wear out then really doesn't it :rolleyes:
phatgti
We dont run in the big ends on my alfa engines but we get the rods honed so they are true to begin with - the clearances are correct then so no need for running in.
ALEX
Very controversial this, but if you didn't replace the piston rings you should be good to go.
But just sign this for me.
Disclaimer:
I huzzer hereby acknowledge the advice given is not supported by any scientific evidence and I will not hold ALEX responsible for any damage to myself or the engine in question.
Signed........................
Edit: in other words, It's best to be safe than sorry
Edited by ALEX
