Dave87 0 Posted June 9, 2007 hi people i keep having problems with getting fuel to my carbs when i'm driving along. it fells like its runing out of fuel even when i now theres plenty of fuel in the tank. My set up from the carbs is 45 webers, filter king, facet pump, gti fuel filter then fuel line to the tank. any ideas? Share this post Link to post Share on other sites
Richie-Van-GTi 81 2 Cars Posted June 10, 2007 Is the facet getting a good earth, they are very sensitive to this and a bad earth generally makes them pump poorly. Share this post Link to post Share on other sites
Dave87 0 Posted June 10, 2007 cheers i look into that i've earthed it of one of the threads behind the feul filter, i try a dif one. cheers Share this post Link to post Share on other sites
StuF215 1 1 Cars Posted June 12, 2007 I had this problem with my Mi. Fitted 10mm fuel lines from tank to carbs. Cured it completly. Not sure if you get this issue with an 8v, but don't see why not. Might not be the pump, but the pump not getting enough fuel. Maybe tight bend or Kink in one of the lines? Stu Share this post Link to post Share on other sites
