niklas 1 Posted June 6, 2007 Has anyone used Gentherm2 to calculate a new thermfactor file for the OE sensor? Gentherm2 can be found here: http://www.not2fast.com/megasquirt/doc/gentherm2.html Share this post Link to post Share on other sites
Malachy 0 Posted June 6, 2007 (edited) no but i have used easytherm which works spot on whole forum with links how to use and where to download is http://www.msefi.com/viewforum.php?f=26 regards Andy Edited June 6, 2007 by Malachy Share this post Link to post Share on other sites
niklas 1 Posted June 7, 2007 no but i have used easytherm which works spot on whole forum with links how to use and where to download is http://www.msefi.com/viewforum.php?f=26 regards Andy What values did you use as input? Share this post Link to post Share on other sites
Bats 0 Posted June 7, 2007 I used the OE sensor on my 205 1.9 and used -10 deg C 9500 ohms 20 deg C 2400 ohms 80 deg C 330 ohms These settings worked ok on my megasquirt setup. Tip:- use a minitimer connector with the easily detachable spring clip type rather than the cheapo OE type that are a nightmare to remove when the plugs are in an awkward place to get to (as in the 205 coolant sensor position). Share this post Link to post Share on other sites
niklas 1 Posted June 7, 2007 I used the OE sensor on my 205 1.9 and used -10 deg C 9500 ohms 20 deg C 2400 ohms 80 deg C 330 ohms These settings worked ok on my megasquirt setup. Tip:- use a minitimer connector with the easily detachable spring clip type rather than the cheapo OE type that are a nightmare to remove when the plugs are in an awkward place to get to (as in the 205 coolant sensor position). Sweet! Thanks! All connectors that I replace are the spring clip type Actually the OE connectors are quite easy to remove, just rock hard left-right while you pull a little.. Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted June 8, 2007 useful info, thanks . am i able to use the same (i mean the very same) coolant temp sensor both for MS1 and Motronic at the same time or will they both work incorrectly as a result? Share this post Link to post Share on other sites
niklas 1 Posted June 9, 2007 useful info, thanks . am i able to use the same (i mean the very same) coolant temp sensor both for MS1 and Motronic at the same time or will they both work incorrectly as a result? You'll be able to use the same! Share this post Link to post Share on other sites
