Banjo
Dump Valve Location
Banjo
Is it ok to put my dump valve on the hot side of the intercooler rarther than the cold side? Its a vent to air piston type, cheers. :(
Ben
Mikey G
Xantia Activa has a DV take off ready on the hot side, and iirc my Cosworth was also on the hot side with the standard DV.
Banjo
Its a mk2 Golf with a 20vt running on DTA, from what i've read it wants to be as close to the throttle body as possible so the gas can get out quickest when the throttle is shut..?
Ben
TEKNOPUG
Why cant you fit it on the cold side?
Banjo
I havnt got enough space
pdd144c
As close to the TB is ideal, but not essential.
sonofsam
How tight is it? you can buy silicone bends etc with DV take-offs. If that's any help.
