foreigner 0 Posted June 4, 2007 I just found perfect 3 door, no scratches. it's 1.1 so I presume it's TU. What is involved regarding engine and gearbox mounts. I am going to use gti subframe. Is there any other way to fit top mount apart from removing original and welding xu mount in and the same for gearbox mount? I am not worried about arches and stuff as it will have 14' wheels. Is there someone who's done it? So there will be hands on experience. My only worry is the top mount. Share this post Link to post Share on other sites
Sandy 191 Posted June 5, 2007 What year is it? From late 89 TU and XU 205's have the same upper right inner wing mounting, it's only the subframe gear linkage mounts that are different. Share this post Link to post Share on other sites
foreigner 0 Posted June 5, 2007 What year is it? From late 89 TU and XU 205's have the same upper right inner wing mounting, it's only the subframe gear linkage mounts that are different. it's 93 so it should be ok then? Share this post Link to post Share on other sites
