Guest lammy chop Posted June 4, 2007 (edited) some times my petrol pump runs on after the ignition is turned on my phase 1 1.9 any one know what the problem would be Edited June 4, 2007 by lammy chop Share this post Link to post Share on other sites
Guest lammy chop Posted June 4, 2007 tach relay? wheres that in the fuse box ? and whats it look like Share this post Link to post Share on other sites
Mikey G 3 Posted June 4, 2007 Its under the drivers side dash and is the big relay next to the ECU. Share this post Link to post Share on other sites
Guest lammy chop Posted June 4, 2007 Its under the drivers side dash and is the big relay next to the ECU. cheers lads any body got one going spare for sale Share this post Link to post Share on other sites
t16ryan 1 Posted June 4, 2007 i should have if you get stuck for one Share this post Link to post Share on other sites
Guest lammy chop Posted June 4, 2007 i should have if you get stuck for one blinding when you have a spare 5 mins that would be great Share this post Link to post Share on other sites
t16ryan 1 Posted June 4, 2007 ok will dig it out for ya email me ryan_moledina@hotmail.com with ya addy Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted June 4, 2007 *maybe* you can just hear the fuel pump priming the system? just a thought . Share this post Link to post Share on other sites
Guest lammy chop Posted June 5, 2007 *maybe* you can just hear the fuel pump priming the system? just a thought . no defo keeps going it drained the battery had to unplug it by the pump Share this post Link to post Share on other sites
zowow 0 Posted June 6, 2007 hmm, mine does this too, but im not sure if its cause its not all wired up properly, seems to be something to do with the earth maybe, unless its a relay thats really easy to blow if you connect the coil up the wrong way round :S Share this post Link to post Share on other sites
Phil H 16 Posted June 7, 2007 tried flicking the relay to get it to go off, sometimes works as a short term fix Share this post Link to post Share on other sites
