DamirGTI 344 Posted June 4, 2007 Hello ! I've notice that i have two types of injectors : 4 injectors (currently fitted to the engine) with numbers - 0280150702 and 4 inectors (spare) with numbers - 0280150762 All injectors are yellow , and i found that this 028015072 has 189.2cmf flow , and 0280150762 has 213.9cmf flow .. Is this true or not ? Thanks Damir Share this post Link to post Share on other sites
inferno 1 Posted June 4, 2007 Hello ! I've notice that i have two types of injectors : 4 injectors (currently fitted to the engine) with numbers - 0280150702 and 4 inectors (spare) with numbers - 0280150762 All injectors are yellow , and i found that this 028015072 has 189.2cmf flow , and 0280150762 has 213.9cmf flow .. Is this true or not ? Thanks Damir the same table you found that, does an injector number ending 701 have a 240cc flow rate? if so then yes. Share this post Link to post Share on other sites
DamirGTI 344 Posted June 4, 2007 Hi ! For injector number 0280150701 says 226cmf flow in this table form which car are these ? pug or non pug car ? num. 702 is from :Alfa v6-3.0l, BMW 6-3.0l, 6-3.5l, Citroen 4-2.0l, Fiat num. 762 :Citroen 4-1.9l, Peugeot 4-1.9l, Volvo 4-2.3l but for 701 injector dosn't write the type of a car-engine Which numbers are mi16 injectors ? Damir Share this post Link to post Share on other sites
inferno 1 Posted June 4, 2007 strange, what charts are your using?there standard 8v turbo ones on say a 406. Share this post Link to post Share on other sites
DamirGTI 344 Posted June 4, 2007 i was looking at this table : http://users.erols.com/srweiss/tableifc.htm Damir Share this post Link to post Share on other sites
DamirGTI 344 Posted June 4, 2007 found another table , here says 240cmf for that 701 injector : http://www.max-boost.co.uk/max-boost/resou...-basic-info.xls Damir Share this post Link to post Share on other sites
lee-bg 0 Posted June 4, 2007 ..701 - 240 cc ..762 - 214 cc - mi16 type ..702 - 189 cc - Alfa 3.0 etc. Share this post Link to post Share on other sites
