Guest serioussam
306 Suspension On 205
Guest serioussam
Is it true that you can put 306 suspension (gti6 front struts etc) on a 205?
Yes, considered a slight upgrade too, slightly stiffer rate of damping.. :D
midnight motorsport
agreed, i have a set of 306 bilsteins allround, the only difference is that the anti rollbar pionts are in a slightly different place, but doesnt seam to cause any probs,
also you need to use 205 springs and top mounts,
but the setup works perfectly and seams v good
DaveK
do 306's use the rear beam setup as well
Edited by DaveK
No the beam's different. Just the rear shocks can be used on a 205.
RossD
You can use the 306 trailing arms on a 205/309 beam though, if you are into tweaking your suspension :D
and 205parts will modify the 306 anti roll bar to fit a 309 (and maybe 205?) rear beam.
Yup, they can do both 205 and 309 length bars :D
midnight motorsport
You can use the 306 trailing arms on a 205/309 beam though, if you are into tweaking your suspension :)
when you say 'tweaking your suspension' what do you mean? is the camber/castor different? as i know the arms are very similar,
also why do people fit zx arms? are these any different?
cheers, jay
acox99
what about 306 coilovers, will they still fit fine?
RossD
Yep, thats it, the camber and the toe angles are different. There is another thread on here somewhere all about it.
