eob 7 Posted June 2, 2007 Ok, most of you will remember the hassle I was getting from removing the drums from my 205 1.6 GTi, so I've decided to do the sensible thing and refurb the awesomely straight back axle from my donated 1.0 Junior with under 60k miles. No lean, no nothing, but... Here's the thing. As far as I can tell, the only difference between the GTi/base model axle is: 1. The GTi has a different 'bump' in the tube (doesn't matter) 2. The GTi has thicker torsion bars (have a set on the way) 3. The GTi has wider drums. Now, question Is there any other common Peugeot (306, 309 etc) that uses the same drums!? Share this post Link to post Share on other sites
Jrod 7 Posted June 2, 2007 Thicker ARB aswell. I've some drums here if you need them, Removed them from my beam when I swapped to discs. Share this post Link to post Share on other sites
eob 7 Posted June 2, 2007 I think I might only need one but... you're on Oh, and, question, how did you get the front track on your car to be so wide Share this post Link to post Share on other sites
Jrod 7 Posted June 2, 2007 Just give me a Pm If you want them. REally low offset, going to even wider now with my 309 bones and 8 inch wide wheels. Share this post Link to post Share on other sites
