tomo205
What Have I Done?
tomo205
took the supercharger off my car as it needs re-building and put a normal manifold on i think i have done something worng as it's blowing out clouds of white smoke
Richie-Van-GTi
not sealed against the water holes on the front of the head and sucking coolant through intake, or piped the coolant hoses onto throttle body wrongly.
tomo205
i think it could be sucking coolant through intake would this off caused any problems?
Richie-Van-GTi
not if it was only run for a short time and the coolant didnt drop dangerously low with a very hot engine.
tomo205
the car was ran for just a short time, I have tightened everything up and I'm not losing any coolant, but she is still smoking bad? white smoke and i have mayo on the dipstick
matty_gti
OOo sounds dodgy :wacko: ....thats why i didnt buy the lynz 205 as the seller was very vague in anserwing questions....but im sure theres some silly logial reason. It may take a while for any water in the exhaust to evaporate out.
However mayo on the dip stick doesnt sound good. Could be the head gasket and water is getting into your oil but if your not loosing any coolent then who knows???....
Edited by matty_gti
Pug_Power_Dave
Doesnt sounds too good, usually a head gasket if theres mayo in your oil, there mayo in your oil filler to? sometimes it can just be condensation in the engine if its been stood a while!
Poss try an oil and filter change and engine flush then see if it comes back!
Dave
tomo205
OOo sounds dodgy :) ....thats why i didnt buy the lynz 205 as the seller was very vague in anserwing questions....but im sure theres some silly logial reason. It may take a while for any water in the exhaust to evaporate out.
tell me about it :wacko: i'm a bit sorry i bought it now the 205 lynx it's nothing like lynx it doesn't attract women just problems it wasn't smoking b4 i changed the manifold?
Pug_Power_Dave
I'll swap you it for a can of lynx deoderant then! see if you have more luck with that!! lol
Super Josh
It did sound a bit rough in the vids, what engine management is it running? Nice 'Charger whine though :wacko:
Josh
jshep205gti
I disagree...it's not usually the head gasket. It's usually blocked breathers and/or too thick oil.
Do you take your head off everytime there is mayo in your oil filler or dipstick?!?!
Shep.
Pug_Power_Dave
Shep.
All the times it's happend to me the heads been gone and not blocked breathers, as have tried cleaning them but to no avail (on a range of cars here not just 205's). was propper f**ked as they say :lol: lol, or the condensation thing if they've been stood, but then that usually clears up with abit of running and oil change.
Dave
max0
id do a quick oil change, and check the old oil for water. Id also try a compression test on each bore to see if this highlights a head gasket fault... very strange it didnt do it before changing the manifold tho... are you 100% all the pipes are on correct?
