Trick
Rad Drain Plug
Trick
Should it have a washer on?
DaveK
rubber ring on mine
mickie
yeah or else how could it seal?
Trick
YEah thats what i thought.
Mine did....before i went for an mi conversion. came back without one.
i put one on today and it sealed but for 5 mins. then started leaking....wouldnt seal, guess i need a proper fitting one from Pug.
Anyone know what size?
Is it an o ring or a fibre type washer?
lagonda
Just a rubber washer. My radiator was new in 2001 & the washer is perished already. Larf!
Frankly any rubbere washer should do, it's not under any really great pressure, just make sure it's a good fit. The drain plug on mine is plastic ... if yours is metal a fibre washer would be fine, but with plastic I think you'd strip the thread before it would be tight enough to seal properly.
Trick
any washer i put on kept failing...
noticed that my plastic drain plug was cracked on the thread, not visible until it put under pressure.
problem solved
