boldy205 75 Posted May 28, 2007 Hi, does anyone know what the sensor on the back of the alloy MI16 block is? also how many wires go to it (as i think it has 2 terminals, and is the wire that goes to it white in colour??) Also on the back of a 8V stat housing there are two water sensors next to each other, what colour wires go to each sensor as i have 1 red and 1 yellow wire but am unsure on which sensor they go to? thanks Matt. Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 28, 2007 The sensor on the back of the Mi16 block if its a two prong one is for the oil level sensor & not used in a 205. The wires to the sensors on the 8v thermostat housing are red to the smaller of the two senders (often has a red ring on the sensor) & yellow to the taller sensor (often has a green ring on) iirc. If you cross connect them all that happens is the water temp guage won't work so you just swap them over if this happens. Graham. Share this post Link to post Share on other sites
boldy205 75 Posted May 28, 2007 brilliant thanks! its a random one but i have a white wire left over the same size as the two sensors. is this the wire which goes to the sensor in the sump, poss temp sensor?? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 28, 2007 Quite possibly, if it has a ring terminal on the end its almost a certainty. Grahasm. Share this post Link to post Share on other sites
boldy205 75 Posted May 28, 2007 it hasnt got one there now as it fell off monts ago(at the begining of my rebuild/never ending fight to get my car back on the road!!) as the wire was crusty. Thanks Matt. Share this post Link to post Share on other sites
Anton green 12 1 Cars Posted May 28, 2007 (edited) I replaced the sump wire today (oil temp sensor). Its a white wire with a small ring termination on the end. It is quite a thin wire which may or may not have been left to rub against the driveshaft by some numpty who cant be trusted to install an engine properly. Edited May 28, 2007 by Anton green Share this post Link to post Share on other sites
boldy205 75 Posted May 30, 2007 Nice one!! Thanks people!! Oh i do like this forum Share this post Link to post Share on other sites
