RHULPUG
Converting Base Model Rear Side Windows To Gti Opening Ones
RHULPUG
I've got a mint base model miami blue 205, and want to convert the rear side windows by installing ones which open outwards as found on GTi,XS,Stdt models but there isn't much info on the search facility. Can anyone please shed some light?
Jrod
Think you just need to remove the plugs that cover the holes on the base model shell and bolt the brackets on.
GTI6BOY
Change the rubbers too?
RHULPUG
So behind the 'plastic covers' there should be something to bolt the hinges to?
Is it as simple as sticking the rubbers to the window frame and can these be bought new?
Edited by RHULPUG
Jrod
Yep just swap the rubbers.
I'm not sure if the holes are behind those plugs but they should be.
boombang
I've got a full opening rear window setup you can have if you want?
Glass, brakets and seals.
Would happily swap for fixed setup.
DaveW
The holes are there, i used big rivets to hold all the hinges in.
RHULPUG
Thanks for the offer but another forum member has already offered.
Thanks for the guidance.
