danpug
Unlocking 306 1.8 16v Ecu
danpug
I've got the opportunity to buy a nice 1.8 16v to replace my shagged engine. Its still running in the car and uses the transponder type immobiliser system, not the earlier keypad setup. My question is how do i ensure the ecu gets unlocked? Is it a case of unplugging it whilst the engine is running? Thanks.
Edit: I'm sure its the same process you need to go through with other engines like the s16 and gti6.
Edited by danpug
Scottieb
does not really answer your question, but is this an all aluminium engine? and what car is it out of?
Scott
danpug
Yep all alloy. Out of a 306 meridian but came in the later 306 xs's, lots of 406's and some citroens.
danpug
Can anybody please help?
205turbo
unplug the transponder when running or just pull the ecu plug, do not connect back in the car if the transponder is still connected as the lock signal will be sent
cheers
paul
danpug
Thanks a ton!
