Bam 0 Posted May 26, 2007 hi folks, i'm thinking about one thing...i need more power, more torque -less mileage...and two turbo's are a lovely think. i know one user had have boosted up to 260hp/440nm with stock turbo's in his 205 -nice thing, but not enough... one question: to wich max power is the bottom end and the head from 407 hdi biturbo good for? any expirience from dutch or french guys? cheers mik Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted May 28, 2007 I think Lybker is the one to talk to in this case. Problem with diesels is that there are no aftermarket programmable ECUs available yet. So you'll have to do with reprogramming the existing ECU, which is a pain in the butt. You'd have to transfer most of the dash, loom and BSI box into the 205 to get the stuff working again. The twin-turbo setup that Lybker uses was by no means with the standard turbo's by the way: setup: turbo: Share this post Link to post Share on other sites
RossD 44 Posted May 29, 2007 I think Bam is talking about the new 2.2 HDi from Pug that uses 2 turbos straight from the factory. 170bhp and LOTS of torque is it not? Share this post Link to post Share on other sites
Bam 0 Posted May 30, 2007 @hilgie nice pictueres, impressive. @rossd yes you are right cheers mik Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted May 31, 2007 I doubt you can get that engine running properly in a 205...mainly due to the Canbus wiring etc. Share this post Link to post Share on other sites
205007 12 Posted May 31, 2007 can network into 205 = a world of pain! master tech at out old dealer says it is possible to disable most of the modules associated and just run a simplified network, but you need the pug computer to do it Share this post Link to post Share on other sites
Hilgie 16 2 Cars Posted June 1, 2007 you need the pug computer to do itYes...that's the hardest part probably. Share this post Link to post Share on other sites
Bam 0 Posted June 3, 2007 that sounds like fun but back to topic...any other expierince about that engine and his max output? cheers mik Share this post Link to post Share on other sites
