Guest sgoaty Posted May 21, 2003 there is a set of alloys in my local sales paper it says ford/peugeot fitment will they fit properly or will i need spacers. Please reply asap so i can phone the guy thanks Scott Share this post Link to post Share on other sites
Guest Graham Posted May 21, 2003 The bolt pattern (distance from the centre) should be the same. I think this is the PCD. You might want to check if its for a four or five stud hub. As for spacers you'll need to know the offset of the wheel. Probably the best way is to try a wheel on the car to check before you buy. Share this post Link to post Share on other sites
Guest 1 FAT PUG Posted May 21, 2003 i had some ford fitment wheels on my old 205, had to get a spacer made up for the back (think it was about 10mm) and bought some 5mm spacers from larkspeed aswell as some longer studs i still got the back spacers and a fiew long studs if you want them it would just cost you a fiew quid in postage unless you live near donny Share this post Link to post Share on other sites
Guest sgoaty Posted May 21, 2003 theyre for a 405 mi16. so i dont know if ill need them thanks for the offer though ill get back to you if i need them. I spoke to the guy and they were fitted to a 205 xs so is the offset for xs wheels the same as that for mi16 ? Share this post Link to post Share on other sites
Guest 1 FAT PUG Posted May 21, 2003 if they came of an xs then they should go streight onto a 405 i would have thought they must have been bought for a peugeot in the first place Share this post Link to post Share on other sites
cybernck 403 1 Cars Posted May 21, 2003 on a 405 they might be fine as it uses different ET (offset) to a 205. otherwise you'll need 20 mm spacers. Share this post Link to post Share on other sites
Guest ash1293 Posted May 23, 2003 i've got a set of MI16 14" five spokes if you are interested? 14"x6" fitted with as new pirrelli dragos. 185/65/14 - i've only done a couple of thousand miles on these. Complete with correct wheel bolts etc. I was running them on my five door diesel 205 so they haven't been thrashed!! lol I'm in the north-east Share this post Link to post Share on other sites
Guest sgoaty Posted May 23, 2003 14" are too small for me thanks anyway Share this post Link to post Share on other sites
Guest BigDave Posted May 23, 2003 Ford and Pug 4 stud pcd's are identical but dont forget the difference in either front or rear wheel drive on the fords. This is always a good guide as to which way the offset will go. Share this post Link to post Share on other sites
