DanS1982 0 Posted May 23, 2007 Hello! Got a slight problem with my 1.9 at the moment. When pulling away or blipping the throttle the car seems to be slightly hesitating. I have not changed anything yet but can someone point me in the right direction as to what this maybe? It has recently had a new AFM. Cheers, Dan Share this post Link to post Share on other sites
matty_gti 20 Posted May 23, 2007 Check out my topic .... http://forum.205gtidrivers.com/index.php?showtopic=75324 Matt Share this post Link to post Share on other sites
DanS1982 0 Posted May 23, 2007 Check out my topic .... http://forum.205gtidrivers.com/index.php?showtopic=75324 Matt Thanks but my problem is nothing like that I'm afraid. All 4 cyliners are firing fine, just not power for a split second when you initially move away...... then all is fine. Dan Share this post Link to post Share on other sites
DamirGTI 344 Posted May 23, 2007 (edited) Hi ! Most likley drty-blocked injectors , take them to "ultrasonic cleaning" and change fuel filter after that . hope this helps Damir EDIT: just notice - about that new AFM , you must check fuel mixture and reset if necessery Edited May 23, 2007 by DamirGTI Share this post Link to post Share on other sites
DanS1982 0 Posted May 23, 2007 Hi ! Most likley drty-blocked injectors , take them to "ultrasonic cleaning" and change fuel filter after that . hope this helps Damir EDIT: just notice - about that new AFM , you must check fuel mixture and reset if necessery The injectors were refurbished before i bought the car (Oct 06) so dont think it would be that either. Might be worth a look though. Share this post Link to post Share on other sites
