dave_gti 0 Posted May 23, 2007 I got some problems with the exhaust that has restriced it a bit, just hopin a local exhaust dude will be able to sort summat out . I should get an extra 10ish top end bhp and a even higher torque increase. i dont think its too bad Share this post Link to post Share on other sites
dave_gti 0 Posted May 23, 2007 its the alloy 1.9 mi Share this post Link to post Share on other sites
smckeown 1 Posted May 23, 2007 worth posting the spec for people to comment on sport, like cam, compression, induction, any headwork etc Share this post Link to post Share on other sites
16v205 9 Posted May 23, 2007 What you done to it? Thats a lot of torque for a mi16?? Rich Share this post Link to post Share on other sites
Ahl 4 Posted May 23, 2007 Seems like nice solid figures. I've got the usual question with this sort of thing though - what was the figure at the wheels? Share this post Link to post Share on other sites
Dino 3 Posted May 23, 2007 What you done to it? Thats a lot of torque for a mi16?? Rich Not really - my Mi16 was very similar - although peak torque was at a heady 6650rpm Share this post Link to post Share on other sites
dave_gti 0 Posted May 23, 2007 sorry i should have put more info, just to keen to see what people think of the figures, because i dont know much about the mi engines, so here goes - 1.9 Alloy Block MI16 (XU9J4) ► CatCams 4900526 ► 3 Angle Valve Seats ► ARP High Strength Rod Bolts ► OMEX 600 Mappable ECU ► Pipercross Air Filter ► Magnex Back Box ► 1600 GTI Box (Mi16 5th & 1.6 GTI Final Drive) With Quick Shift Linkages i dont have the figure at the wheels, thats all i got back from des. ill get it done again when i sort the exhaust out next week Share this post Link to post Share on other sites
Ahl 4 Posted May 23, 2007 Cool, so a nice figure for not too crazy a spec. Have you bigger injectors too? You say the exhaust needs sorted out - whats wrong with it? Share this post Link to post Share on other sites
SPGTi 2 Posted May 24, 2007 So yours was the other one down there. This was mapped at the same place as Sean's 8v. Steve Share this post Link to post Share on other sites
dave_gti 0 Posted May 24, 2007 So yours was the other one down there. This was mapped at the same place as Sean's 8v. Steve Possibly, Grey With Lamps? Share this post Link to post Share on other sites
dave_gti 0 Posted May 24, 2007 Cool, so a nice figure for not too crazy a spec. Have you bigger injectors too? You say the exhaust needs sorted out - whats wrong with it? cheers matey, its on std injectors, the exhaust is as if its been crushed cant understand how, but there is a 2" long section of it by the bulkhead, so its restricting a lot. i am gutted i hadnt noticed it before (its quite hard to see it) otherwise id of had it sorted before it got it mapped etc Share this post Link to post Share on other sites
Ahl 4 Posted May 25, 2007 Ah, It'll be interesting to see the results after sorting it out then. I've read on here a few times that the standard injectors are only good up to 180hp or so. Perhaps you'd gain something by fitting and mapping slightly larger ones. My engine is the same spec as yours less the omex (to begin with anyway) so I'll follow your progress with interest. *edit* Meant to ask, have you swung the cam timing at all? Share this post Link to post Share on other sites
