IanG Dorset 0 Posted May 22, 2007 Hi My rear washer jet is not working. There is plenty of water in the tank in the boot but nothing happend when i try to get it to pump out. there is no sound of any thing trying to work either and the fronts are perfect. When abouts is the pump located? Is it the same as the one for the front? What should i try to do 1st? Thanks for any help Share this post Link to post Share on other sites
All Praise The GTI 3 Posted May 22, 2007 there is a separate motor for the rear washer its located behinde the separate bottle in the boot. two torx head screws and pull the bootle out and its on the back. had to do this on my 1.6, i modified a 106xsi pump off my old car thta i was breaking to save a few quid. all motors are the same virtually Share this post Link to post Share on other sites
IanG Dorset 0 Posted May 22, 2007 Thank You I will update tomorow after a bit of investigation. Share this post Link to post Share on other sites
