Wicker man 2 Posted May 20, 2007 im going to be lowering my rear beam to go with the sprintline kit im going to order in the morin, via the guide on the main site now i have 100's off sockets braker bars etc so i pretty much have the tools cover bar a few things a type 40 torx tool im going to get off my mechinic 19mm head bolt. The bolt needs to be at least 100mm long were can i get something like that? i take it any 19mm bolts that 100mm long wood do? anything else i need? cant remember reading about needing anything else Share this post Link to post Share on other sites
Jrod 7 Posted May 20, 2007 You can use a bendix caliper bolt Either one of the fronts if it's a 1.6 or one of the rear if its a 1.9 Share this post Link to post Share on other sites
Wicker man 2 Posted May 20, 2007 arha 1.9 so thats ok Share this post Link to post Share on other sites
Miles 331 1 Cars Posted May 20, 2007 And a BFH, Big F.... Hammer Share this post Link to post Share on other sites
V8Pete 0 Posted May 21, 2007 Doesn't need to be 100 mm long. 40 is more than enough from memory. Share this post Link to post Share on other sites
Wicker man 2 Posted May 21, 2007 Miles said: And a BFH, Big F.... Hammer yep no problems there i have a range off hamers Share this post Link to post Share on other sites
max0 5 Posted May 21, 2007 wire brush is useful for cleanin the rust from splines etc. Sounds like you will prob already have it tho. Good luck Share this post Link to post Share on other sites
Wicker man 2 Posted May 21, 2007 ive sorted it all now my mechinic will lend me a torx tool thingy & he's found me a 19mm bolt now its only 90mm long so that should be ok? does it need to be threaded all the way down? Share this post Link to post Share on other sites
Jrod 7 Posted May 21, 2007 No but it needs to be the right thread... Share this post Link to post Share on other sites
V8Pete 0 Posted May 21, 2007 (edited) The main thing is to make sure the 19 mm head bolt is M12x1.5. That's not the most common M12 pitch. Should only be a couple of bucks from a bolt shop so I don't really know why people seem to have so much trouble with them. I used 35 mm long bolts and that was plenty of length. It might be handy to have a bolt, nut, and big washer to suit the torsion bar thread, but I can't remember what size that is. Edited May 21, 2007 by V8Pete Share this post Link to post Share on other sites
Wicker man 2 Posted May 21, 2007 V8Pete said: M12x1.5 need to find 1 off them then Share this post Link to post Share on other sites
Jrod 7 Posted May 21, 2007 As I said, the bolt that holds your calipers on the rear. Share this post Link to post Share on other sites
Wicker man 2 Posted May 21, 2007 Jrod said: As I said, the bolt that holds your calipers on the rear. i'd rather get a bolt off my mechinic than use 1 from the car that mite get buggered up for whatever reason i dont want to be able not to put it back together coz off 1 bolt on a sunday afternoon Share this post Link to post Share on other sites
