KaspaCti 0 Posted May 19, 2007 Hi, Just a quick question, Does anyone know what torque setting I should use to tighten the 6 bolts holding the subframe to the car? I've had a look in my Haynes and done a search on here but can't seem to find an answer. Many thanks Sean Share this post Link to post Share on other sites
edthedrummer 0 Posted May 19, 2007 according to the haynes manual, on page 10.2 of the peugeot 205 manual, subframe bolts: Front 75Nm Rear 53Nm hope it helps. Share this post Link to post Share on other sites
KaspaCti 0 Posted May 19, 2007 edthedrummer said: according to the haynes manual, on page 10.2 of the peugeot 205 manual, subframe bolts: Front 75Nm Rear 53Nm hope it helps. Brilliant, thanks for that, I must be going blind because I scoured the Haynes manual for ages and couldn't find it Thanks again Sean Share this post Link to post Share on other sites
edthedrummer 0 Posted May 19, 2007 KaspaCti said: Brilliant, thanks for that, I must be going blind because I scoured the Haynes manual for ages and couldn't find it Thanks again Sean Don't mention it. You were lucky i am sat here with not a lot to do, and just as it happens i have my two trusty peugeot haynes manuals next to me. Although i didn't doubt you when you said you couldn't find it in there, i have found the manuals to be totally useless for some things. Ed. Share this post Link to post Share on other sites
swordfish210 20 Posted May 20, 2007 they're not in my copy of the haynes manual either , i ended up doing them up to the FT +1 setting Share this post Link to post Share on other sites
Ahl 4 Posted May 20, 2007 When I was trying to remove a subframe from a scrapyard 205 one day, I managed to tighten the bolts instead of loosening them! Anyway, it didn't take much more than FT before they sheared, so I'd be wary of doing them up too much. They aren't particularly thick bolts. Share this post Link to post Share on other sites
swordfish210 20 Posted May 20, 2007 well i was only using a 1/2 drive ratchet so i can only get about 60-70nm of torque out of it Share this post Link to post Share on other sites
