Dave87 0 Posted May 19, 2007 help needed people i've just put a xu9ja with 45s into what was a 1.1i 205 mardi. i've put the gti clocks in and wired in the gti loom of the the clocks into the mardi fuse box but i've only got the feul gauge and the speedo to work. When i put the ignition on i only get the hand brake, battery hazards indicators side dipped and full beam lights to show. plus does the green wire of the coil go to the rev counter wire 112?? Any ideas.... Dave Share this post Link to post Share on other sites
inferno 1 Posted May 19, 2007 sounds like a bad earth, or sometimes a blown ignition fuse... Share this post Link to post Share on other sites
Dave87 0 Posted May 19, 2007 the engine runs and i'm driving it. where would i look for the earth i was wundering if i needed to use a gti fuse box with its relays or if i could just put the gti relays into my mardi fuse book. Share this post Link to post Share on other sites
inferno 1 Posted May 19, 2007 does your car have the loom with the brown multiplugs under the dash and above the gearbox like a gti? sounds like your missing all the sensers... you may need part of the gti loom from the clocks. sorry when i said a bad earth i thought all the lights came on together Share this post Link to post Share on other sites
Dave87 0 Posted May 20, 2007 under the dash to the right of the heater i've got two brown conectors one large one small the large is conected i'll have to look around the fuse box for brown conectors. Share this post Link to post Share on other sites
