Veero 1 Posted May 18, 2007 Would it be possible for anyone to measure this. I need to know the approximate angle the that back face (exhaust manifold mating surface) of the head of an Mi16 sits at in relation to the 2-1 part of a 4-2-1 manifold(which I assume is virtually parallel to the ground) in a 205 in the following configurations: 1) Normal length lower engine mount 2) Extended lower engine mount to tilt the engine Excuse the MS Paint pic. If anyone can get me one or both of these angles that would be a life saver. I dont know how to suggest making sure the car's flat Thanks Veero Share this post Link to post Share on other sites
Nathan 0 Posted May 18, 2007 I have a digital angle measurer and a level workshop floor, but only have a 8v engine so I'm not sure if I can be of help or not???? Share this post Link to post Share on other sites
welshpug 1,666 Posted May 18, 2007 the engine sits at 30 degrees, all XU engines do Share this post Link to post Share on other sites
Veero 1 Posted May 19, 2007 Wow the perfect kit for the job. I can't remember how the 8v and 16vs compare, probably quite close but really need to be an Mi16. Cheers though Veero Share this post Link to post Share on other sites
Veero 1 Posted May 20, 2007 Ok so the Xus sit at 30 degrees meaning the angle I was after should be 60 degrees. I have been told the angle on the manifold I am after is approx 55 degrees. Can someone measure a tilted Mi, if it comes out to 55 degrees then it looks like this ones designed for a tilted Mi. Worst comes to the worst I can get it tweaked slightly or get some flats put in I suppose. Veero Share this post Link to post Share on other sites
