24seven
1.6 Rear Hub Nut Diameter?
24seven
stupid staked nut! can't get rid of the stake, and for some reason I don't have a socket that'll fit the rear, though I'm sure I had one that fitted the front (are they different or am I losing it?)
anyway how big is it? all I want to do is unseize the handbrake :)
Ahl
I think its a 30mm. Once you get a proper socket on it, the stake should pull out. I think the front is 32mm on a 1.6.
24seven
largest socket I can find in teh garage is a 1 3/16, but I'm positive I had one go on the front before. this annoys me...
another thing, is the passenger side one a lefthanded thread?
Edited by 24Seven
Other way round Ahl, afaik all rears are 32mm but the fronts are 30mm on a 1.6 / base & 35mm on a 1.9 GTi.
Graham.
24seven
now that's just annoying :):angry::wacko:
steve@cornwall
I tap a flat screwdriver end -( the ones you fit into a cordless driver) to bend the staking back, less effort to undo the b'stards then :huh:
24seven
did that with a drift, only couldn't turn i. found a mate with a 32m socket so it's all good, cheers.
