ajones12 0 Posted May 17, 2007 After putting a new clutch on my 1.9 GTi (BE3 gearbox?) I had this left over: The picture isn't too clear, but its about 50mm long, brown and plastic! I remeber taking it off, but can't remember where it goes!!! Can anyone point me in the right direction?? Thanks. Share this post Link to post Share on other sites
boombang 2 Posted May 17, 2007 looks like the end of a dipstick to me? Share this post Link to post Share on other sites
tom_m 0 Posted May 17, 2007 looks like the end of a dipstick to me? i concurr Share this post Link to post Share on other sites
welshpug 1,671 Posted May 17, 2007 yep! end of the dipstick, I found the end of the thermostat bleed screw in the crud on top of my gearbox. Share this post Link to post Share on other sites
ajones12 0 Posted May 17, 2007 Mmmmm.........interesting.......where does it go?? I don't remember taking it off the dipstick itself. From memory it came from the back and towards the bottom of the engine! Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted May 17, 2007 dipstick is located behind the dizy area, look for a tube coming up from bottom of the block at the back towards the dizzy. Share this post Link to post Share on other sites
ajones12 0 Posted May 17, 2007 dipstick is located behind the dizy area, look for a tube coming up from bottom of the block at the back towards the dizzy. Thanks for the reply, does the plastic thing sit into the tube? If so which way around or is it obvious? Share this post Link to post Share on other sites
jas-E 1 Posted May 17, 2007 looks like the end of a dipstick to me? didnt think the end of a dipstick is 50mm long.. Share this post Link to post Share on other sites
boombang 2 Posted May 17, 2007 looks identical to an aftermarket dip-stick head to me still. The plastic is moulded around the metal, but the plastic has been known to snap and metal section come out. Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted May 17, 2007 the dipstick should all be one unit, the top shouldnt be seperate like that, it will sit in the top of the tube but it wont be secure and will probably of gone missing after a drive. best option is get another dipstick from somewhere. Not that expensive new and sure a fellow member will have a spare if you stick a wanted ad up Share this post Link to post Share on other sites
ajones12 0 Posted May 17, 2007 the dipstick should all be one unit, the top shouldnt be seperate like that, it will sit in the top of the tube but it wont be secure and will probably of gone missing after a drive. best option is get another dipstick from somewhere. Not that expensive new and sure a fellow member will have a spare if you stick a wanted ad up Cheers guys! Share this post Link to post Share on other sites
ajones12 0 Posted May 17, 2007 Having re-read the posts it's not the top of the dipstick i.e. the bonnet end, I definitely removed it from the bottom of the engine at the back. Or have I mis-read the postings??? Share this post Link to post Share on other sites
Grim.Badger 15 Posted May 17, 2007 Having re-read the posts it's not the top of the dipstick i.e. the bonnet end, I definitely removed it from the bottom of the engine at the back. Or have I mis-read the postings??? It will have snapped off and fallen down the back of the engine ending up where you found it. The rest of the dipstick should therefore still be in the engine Share this post Link to post Share on other sites
mak 0 Posted May 17, 2007 just pull the di[stick out with a set of pliers and put a new one in, sourced from a scrappie for a pound. If theres no dipstick it will be from a previous owner. I found a rather nice 13mm spanner in my engine bay when I took the engine out..result Share this post Link to post Share on other sites
ajones12 0 Posted May 18, 2007 just pull the di[stick out with a set of pliers and put a new one in, sourced from a scrappie for a pound. If theres no dipstick it will be from a previous owner. I found a rather nice 13mm spanner in my engine bay when I took the engine out..result The top of the dipstick is still there! Any ideas what it could be???? Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted May 18, 2007 its definatley the end of a dipstick, prehaps the previous owner replaced it already and its just been trapped somewhere and you have no need to worry about it, just throw it away. Share this post Link to post Share on other sites
