yeti-dj
Mi16 Engine Mount...again..
yeti-dj
hello, have destroyed the drivers side engine mount in the old 205 fitted with an Mi16 and havin trouble gettin a new one that fits. Problem is the new one i got seems to be about 4-5mm taller than the old one so now the cam cover hits the brake servo.
I take it there must be slight differences but where do i get the one that i need???
Did do a search but couldnt find the answer so please help.....
cheers people........
chris 417 mi
i fitted a new mount from a gsf equivalent parts supplier last year and it fitted fine :lol: , post a pic of your old mount, that might shed a bit of light on the problem !
James_m
How does your exhaust manifold fit in relation to the bulkhead now? is it so high up the downpipeis close to/ hits the bulkhead?
4-5mm sounds about right for a worn mounting, new ones will be taller, my bet is that the engine was fitted when an old mount was in place hence the clearance problems weren't evident.
yeti-dj
hello, yes the mount was old when i fitted the engine so that could be the problem.
As for the exhaust manifold/downpipe i have had to cut alot off the downpipe to get it to clear everything fine so guessing fitting a new mount will cause problems with this, hopefully getting a 4 branch from Miles though soon so will get rid of the re-angled thing.
I did try the new mount and when wellying it turning right the cam cover hit the brake servo and caused alot of vibration through the pedals, how do i get round this problem then if i fit the new mount?
yeti
Edited by yeti-dj
