zowow 0 Posted May 15, 2007 I know this is a silly question but this is the pipe bit on the back of the block isn't it.. and i noticed the 1.6 and 1.9 ones are slightly different but probs fit. Do you think it matters? T17960 WATER PIPE-METAL 205 GTi (JOINS TO BOTTOM HOSE) 9.50 Add Share this post Link to post Share on other sites
welshpug 1,666 Posted May 15, 2007 nope, thats the one that goes along the inner wing. to get a new part you'll have to goto the dealers, but they're not that expensive. Share this post Link to post Share on other sites
jas-E 1 Posted May 15, 2007 im pretty sure thats the metal pipe that fits between the water pipe to the radiator and the pipe coming from the back of the block. It is bolted on the inner wing on the driver side wheel arch. If you take your wheel off and remove the plastic cover you will see it. Sits directly infront of the crankshaft pulley. Not sure if the 1.6 and 1.9s are any different though. Share this post Link to post Share on other sites
vern 0 Posted May 15, 2007 If you need a new one, go direct to Peugeot they are about £8, don't pay £20 plus on ebay!. Share this post Link to post Share on other sites
