Guest Stu@ Posted May 12, 2007 Hi all, I finally managed to fire up my mi16 engine for the first time today after swapping a dead starter motor. The engine ran OK but I noticed oil leaking from the join between the throttle body and the afm pipe which I found was coming from the oil filler via the breather hose. Why this would happen and how do I sort it out? Cheers Share this post Link to post Share on other sites
AndyY 0 Posted May 12, 2007 Sounds like you've got pressure getting into you crank casing, Have you got all the pipes to the filler connected correctly? Share this post Link to post Share on other sites
