Turbo7379
Mi16 - Gauze In Filler Cap ?
Turbo7379
Should a 1.9 MI16 have a metal gauze in the filler cap ? There isn't one in mine but I've just found a spare 8v cap with a good gauze & I was going to swap it over .
28CRAIG
Most people take them out as they can brake up and drop in to the sump.
Gtiracer
not only that but sometimes hold moisture and make oil breathing worse IMO
As above, half the reason for some of the mayo in breathing system, condensation etc i presume, then the thing corrodes and drops into the engine, the last oil pump i took out had loads of it inside. Bin it.
Anton green
yep, remove it! ;)
