chris 417 mi
Mi16 Head Torque Settings
chris 417 mi
Anyone advise the torque settings for the head bolts on an early mi16 head ?
Been warned away from haynes and cant really find any as such so far :lol:
Ryan
The Pumaracing site suggests doing them up to 75 lbft in three stages (25, 50, 75). The normal way stretches them some ridiculous amount.
chris 417 mi
Dont suppose you have a link to the site do you ?
I know people who have tried Puma's method and have had weeping head geaskets over time. Your choice, but a set of head bolts isn't very expensive.
Stage I - 60Nm
Stage II - slacken, the 20Nm
Stage III - 300 degrees
The final stage is easy if you have an engine stand, breaker bar and quality torx socket.
Edited by petert
chris 417 mi
engine is on a stand and i have brand new genuine peugeot head bolts waiting to go on .... is this method 100% for sure then ?
Like petert says but from Autodata;
Stage 1; 60Nm.
Stage 2; individually slacken off & tighten to 20Nm then 100' + 100' +100' inturn.
Mikey S
if you tap the bolt holes and use a litle copper slip on the threads and under the bolt heads they torque down alot easier, especially when you have to angle tighten them :lol:
chris 417 mi
cheers for the replys, head will be going back on tonight.
James_m
I did mine using the Pumaracing method , and my head gasket blew F1 style today. Not advisable
James_m
I probably should add the outcome to this defence of Puma's method....
The head gasket did'nt blow, the sensor on the back of the block unwound itself hammering into the bulkhead somewhere, making a horrible metallic noise, and then all the oil getting splashed onto the exhaust manifold led me to beleive the HG had gone.
I thought smoke was leaking out of the back of the headgasket itself somewhere. My bad, and make sure those sensors are done up tight!
It really was F1 style though :blush:
Edited by James_m
Richie-Van-GTi
I believe he put the head on last night as per QEP advice which is the same as petert and graham etc.
matty_gti
I did my 8v head bolts up the same way and one of the bolts stripped out the thread in the block so im considering next doing my headblots up the puma racing way but now im paraniod that there either going to be to tight, or not tight enough!! :P
Mikey S
if you tap the bolt holes and use a litle copper slip on the threads and under the bolt heads they torque down alot easier, especially when you have to angle tighten them :blink:
:P:P
madvalver
Longmans advised to me go to 65lbft in stages(seemed tight enough). Use gen pug gasket. No idea if mines any good yet as havent run it in anger. But its going to be a track toy so if it go's, its go's!
jonnie205
the 300 degrees is very scary and has resulted in me snapping one bolt and stripping the block in another. I now go to 80ft lbs in 3 stages and i find this has been fine. The degrees way can be ok but i would go to 200 not 300
Edited by jonnie205
Richie-Van-GTi
Ive done the 300 degree method on a few engines and never had issues with snapped bolts or stripped threads. Ive always used new bolts and copper slip though, as well as cleaning threads before fitting.
matty_gti
I thought giving a little more that 75ft lbs, like 80ft lbs would have been a better option, just that little tighter.
But i dont get the "65ft lbs in 3 stages"?...surely that isnt tight enough?
I cleaned the threads and used the 'modydulihkuawgsfkgqkef' (somthing or rather!) grease it states in the haynes but thats when it strippped the thread.
Edited by matty_gti
James_m
I dont know if the alloy blocks degrade over time, but pretty much all the threads on my block were very weak, with a few stripping.
That's not a major problem. Just helicoil them if they strip.
matty_gti
But doesnt that leave you a problem when you need to change the HG in future?
not at all, its simply an insert for the bolt to thread into, many expensive bicycle parts have inserts in alloy parts for bolts to thread into.
