RalliArt 0 Posted May 11, 2007 Hello i have a nice 205 GTI 1.6 XU5JA engine, and i have a problem, and the problem is that in low and middle rpm the engine have a strong acceleration but in higher rpm (around and after 5000rpm) the engine looses acceleration and the revs slowly goes to rev limiter around 6400-6500 rpm . Can you people help me with my problem ....some people tell me that the problem is in the fuel regulator or fuel pump...... PLS HELP Share this post Link to post Share on other sites
Andrwn8304 0 Posted May 11, 2007 Hello i have a nice 205 GTI 1.6 XU5JA engine, and i have a problem, and the problem is that in low and middle rpm the engine have a strong acceleration but in higher rpm (around and after 5000rpm) the engine looses acceleration and the revs slowly goes to rev limiter around 6400-6500 rpm . Can you people help me with my problem ....some people tell me that the problem is in the fuel regulator or fuel pump...... PLS HELP Try the Tachometric relay it controls the fuel pump you might also want to check the connections to the fuel pump. Its bolted to the ECU on the drivers side behind the dash. Share this post Link to post Share on other sites
RalliArt 0 Posted May 11, 2007 my drivers side is the left one and the ECU is on the right side are their any difference Share this post Link to post Share on other sites
Andrwn8304 0 Posted May 11, 2007 my drivers side is the left one and the ECU is on the right side are their any difference Might be a bit difference the relay is fed directly from the ignition switch with a 4 pin multi plug which plugs on to the relay. Hope this helps. Share this post Link to post Share on other sites
RalliArt 0 Posted May 12, 2007 This is not the problem everything works can it be something else... pls you are my last HOPE!!!!!!!!!! Share this post Link to post Share on other sites
Andrwn8304 0 Posted May 13, 2007 Try the ECU Temp sender. Does the engine start to splutter and mis-fire at high revs? Share this post Link to post Share on other sites
DamirGTI 344 Posted May 13, 2007 (edited) Hi ! Ignition module maybe Cheers Damir EDIT: or lean mixture from mid to high revs Edited May 13, 2007 by DamirGTI Share this post Link to post Share on other sites
