ashley peddle
Need Peugeot Part Numbers
ashley peddle
i have a rebuilt 1.9 8v bottom end coming my way shortly and the head is currently with QEP so i thought i may as well push the boat out and replace the 20 year old sensors :wub:
soes anyone have the part numbers for all the sensors off thew block? (and a diagram of where they go :blush: )
cheers
ash :o
ashley peddle
anyone?
miamistu
Have a look through the link in my signature - it's got all the part numbers.
If you really want them all (and are feeling rich) you'll need to hunt down the oil pressure gauge + swich, oil temp gauge & water temp senders. (plus anything else i've forgotten)
Super Josh
You should be able to get the oil and water temp senders third party, motor factors, GSF etc. You'll only need to go to the stealer for the oil pressure sensor.
Josh
If the sensors on your existing engine work fine then leave them be - if it ain't broke, don't fix it and all that....
However, if you really want the part numbers:
Oil pressure gauge sender = 1131 69
Oil pressure light sender = 1131 14
Water temp gauge sender = 1337 72
Water temp light sender = 0242 43 (105 degree) or 0242 49 (110 degree)
Oil temp gauge sender = 0242 50
JayCC
Is the oil temp sender the one that plugs into the rear of the sump? Does this have a brown wire that runs to the multiplug?
jim205GTI
Yes it is..... about 20 quid from pug when i asked a few weeks ago, needless to say i haven't been back
