205mattgti
Help
205mattgti
i went to lower my 309 gti rear beam the other day
i have taken out the hex bolt and washer, but the tortion bar is rusted in and i cant budge them
any ideas on how ican get the tortion bars free
the beam was refurbished about 2yrs ago
thanks
matt
Have you removed the bolt at each end of the torsion bar? A torx one (usually) with the offset washer in the radius arm & the nut at the opposite end?
Graham.
205mattgti
yes i have but i cant get the tortion bars loose
they r stuck in
Have you removed ther rerar shock's With themill fitted there will be tension in the torsion bar & you'll have a hell of a job to get it free.
If you have removed them, it looks likes its time to check how well the rebuild was done & take it apart to free the torsion bars off so you can adjust the ride height easily. (& refurb it yourself know).
A few good whack 2lb lump hammer on the radius arm nearest the centre tube should get the bar free from the tube & then you can put an M8 bolt into the stud end (with a large washer to protect the torsion bar) & hit that end to get the torsion bar out of the radius arm with it off the car.
Graham.
205mattgti
thanks will try that
hopefully it will work
