clifton
Pictures Of Stripped Out 205's
clifton
im stripping my 205 out at the moment mainly for fast road use and just the odd track day and just wanted pictures of peoples...
would like to know if people have stripped it fully or just rear seats etc
cheers ben
Rik
Depends how much road noise you can handle, the more interior plastics (e.g. rear door cards/seats etc) you have the less noise you'll get.
Rik
DaveK
Im in the middle of stripping mine, and all i can say is i was shocked at the weight of trim/carpet/underlay/seats etc that came out.
The rear seats arent heavy in the slightest. Take as much as you can out. Id leave the headlining in tho, it was very light and would stop alot of condensation etc
Saying that tho the more you lose the noisier it will get, its a sacrifice hehe
clifton
im not really bothered about the noise...makes it seem faster haha but i just wondered what people left in on a car thats mainly for fast road use
A few pics;
thare's also a few in the link to the white 205 album in my sig. :(
HTH
Jrod
I currently still have my roof lining in, took it out on my last one but the roof flexes sooo much without a sunroof.
Might do it again still though... :(
smckeown
plenty of pics of my 205s on my website
My pug has nothing at all behind the drivers seat and just an upper dash and doorcards in the front. It is very noisy but if you're not bothered then go for it, you won't regret it. I took the headlining out too but as others have said it weighs nothing and the glue it leaves behind looks awful so you'd be wise to leave it IMO.
  jackherer said:
...the glue it leaves behind looks awful so you'd be wise to leave it IMO.
Since when do you drive looking up though... :(
  BazGTMi said:
Since when do you drive looking up though... :)
TBH I didn't even notice it until my mate pointed it out :(
Jrod
The only bit about removing the headlining that bothered me was just how much the roof flexes!
Kev-G
  BazGTMi said:
Since when do you drive looking up though... :P
I don't, but I've seen the roof a few times...
:P:P
Jrod
That's how I had mine originally, slowly got more and more bare... :P
:P:o
:P Does that mean what i think it does? Did you have a 'companion' at the time... :P^_^
Henry Yorke
If you go drastic on your interior stripping out, you are taking weight mostly out of the rear of the car. This can effect the brake compensators / balance and make it more prone to locking up the rears. I know of a couple of people who have been caught out by this.
Battery in the boot is a good step too
Compared to the weight of the carpet, doorcards and underlay, the rear weight you're removing is minimal really. The only weight in the rear are a couple of pretty light seats, a few bits of plastic and a parcel shelf, hardly drastic, and the compensators are crap anyway, better off removed completely, most are old and past it, which is probably more the reason for unbalanced braking.
Richie-Van-GTi
add to that 2 lightweight buckets and a pair of 4 point harnesses and you have my interior :P
No bias valve for my brakes either, never had any isues with rear end locking :P
Ahl
Nice dash!
Jrod
Yep like that dash.
I've got a bias valve for my rears and even with it fully open the fronts lock first, Brembo 4 pots. :ph34r:
Got any more pics of the dash?
Rik
Baz Gti,
Do you have anymore pics of the SD cage? (i presume its challenge spec?)
If so have you any of where its sits on the front struts, and where the plate welds where the rear seats used to be?
Rik
  Rik said:
Baz Gti,
Rik
It is a Challenge spec yes, but afaia they're not allowed to carry through the bulk head onto the front struts, as this is then considered as the suspension mounting point, in effect giving the car a spaceframe type layout.
I don't have any pics of the inside, but basically the two diagonal tubes meet onto a plate that is welded to the floor/tunnel, in front of where the seats would be. This is an addition to the std SD cage, as this one in particular is almost fully welded in.
Edited by BazGTMi
Rik
ah right, i must have the non-challenge spec cage then! as mine go through to the suspension top mounts so wondered what it needed to look like.
Rik
tom_m
:D
