Pts/bilstein Coilover Service
As title really, how can i tell if my billies need a service, is there an easy way to tell? :) -and if so, where can i get this done? Any recommendations?
Any help/guidance appreciated. :(
205wrc
Bilstein service centre in Lutterworth will repair/service your dampers. Give John crooks a ring on 01455 283407. I had my forest insert rebuilt in January, and the total cost was roughly £120 - that included a service, a new rod and two strut top seals V.A.T. and carriage. I think a standard service is about £60 + VAT each
Their address is :-
ThyssenKrupp Bilstein Service Centre
Unit 3,
Swannington Road,
Broughton Astley,
Leicestershire,
LE9 6TU
Hope this helps :(
Aled
Edited by 205wrc
Thanks very much Aled. :) Did you mean £60 each service or per unit?
Any idea how i can tell if they actually need doing? :(
205wrc
£60 per unit.
I suppose the only way you can tell is when you push the shock down the tube and its slow coming back out, or not coming out at all, then its time for a service. With mine, it was easy. The insert popped a seal and there was oil everywhere.
Ah ok, so i guess they're ok for now really, but probably worth thinking about for next year or so!
Again appreciated Aled. :(
