Guest Andyo_123
Head Bolts
Guest Andyo_123
Hi guys i took my head of my 1.9 d6b engine to change the gasket, when i went to torque the head bolts down the 1 at the back nearest the cambelt pieced a hole in the block i had all the spacers on, is 1 bolt shorter than the rest?
Thanks Andy
Sounds like you missed the large spacer as there's 2 on the bolt above the water pump, Seen this loads of times, You might get away with some Chemical Metal in there to seal the hole up but really I'ld weld it up so it won;t let you down
GLPoomobile
That one there uses a thicker spacer (or is it two spacers together?).
You live and learn ;)
PumaRacing
Thanks Andy
http://www.pumaracing.co.uk/PUG2058V.htm
"Favourite trick for newbs trying to replace the cylinder head themselves is to forget that one bolt has a long spacer under it to prevent the bolt breaking through into the cylinder block. Do please try and make a note of which spacer came from where before you add yourself to the long and growing list of plonkers who scrap their engine block while torquing the head bolts up. Basic common sense ought to suffice in that when you drop the bolts into the bolt holes one sticks up a lot further than the rest but basic common sense seems to be a commodity in short supply these days."
Beastie
side note: Basic skills with hand tools also well worth developing as the "feel" of a properly seated and lubricated bolt stretching to length and tightening into the thread is significantly different to one which is bottoming and perforating lumps out of the block :P
Guest Andyo_123
Thanks guys sorted it now, got the hole welded up.
cheers andy
