Guest cookstar
205 Gti Suspension "knocking" When On Rough Surface
Guest cookstar
When on rough roads or going over speed bumps, you can hear a knocking noise coming from mainly driver front.
Is this a commoin problem
What things to check for?
Cookie :D
zilog
Might be the droplinks for the ARB that are worn.
Guest cookstar
Is t a case of replacing them and seeing if its better, or can you see by eye if they have had it
StuF215
Check the ball joint on the wishbone also.
Jack the car up hold the wheel and check for play by moving the wheel from side to side a little. You can usually see where the play is by looking behind the wheel whilst giving it a wiggle.
Stu
zilog
You should be able to feel with your hands if they have any play, one rod end in each end of the drop links that are subject to wear.
