John_205_GTi 0 Posted May 1, 2007 All i need to know is, whereabouts is the resistor located? and, would there be a reason why my car doesn't seem to have one? Share this post Link to post Share on other sites
Grim.Badger 15 Posted May 1, 2007 All i need to know is, whereabouts is the resistor located? and, would there be a reason why my car doesn't seem to have one? Its a cylinder clipped next to the radiator roughly in front of the battery. It looks the same as the dip-dim resistor but that is hidden away. Share this post Link to post Share on other sites
John_205_GTi 0 Posted May 1, 2007 Mine's missing, any idea how much a new one costs? Share this post Link to post Share on other sites
welshpug 1,666 Posted May 1, 2007 About £18 IIRC, asked not too long ago, part number is 1267 12. Share this post Link to post Share on other sites
jackherer 543 Posted May 1, 2007 For better cooling and reliability just replace it with a bit of wire. The only downside is a noisier fan but I see that as a benefit too because I like to hear it working for peace of mind. Share this post Link to post Share on other sites
Grim.Badger 15 Posted May 1, 2007 Mine's missing, any idea how much a new one costs? The cooling fan loom is completely separate to anything else so try tracing it to see if the resistor hasn't ended up anywhere else as you will at least need the connector. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 3, 2007 For better cooling and reliability just replace it with a bit of wire. The only downside is a noisier fan but I see that as a benefit too because I like to hear it working for peace of mind. Another vote for this, as far as I can tell the only reason for slow speed is that full speed is quite loud...one of my GTis has run like this for ages. Share this post Link to post Share on other sites
Powers 13 Posted May 3, 2007 Another vote for this, as far as I can tell the only reason for slow speed is that full speed is quite loud...one of my GTis has run like this for ages. By this do you mean replace the resistor with a bit of wire so that the fan runs all the time? Share this post Link to post Share on other sites
Ryan 99 Posted May 3, 2007 They'll still only run when warm, but they'll come straight on at full speed instead of at half speed first. Share this post Link to post Share on other sites
GTI6BOY 29 Posted May 3, 2007 Its a cylinder clipped next to the radiator roughly in front of the battery. It looks the same as the dip-dim resistor but that is hidden away Thats weird, i have a brown plug hanging and another brown plug with a resistor behind the headlight. My fans were coming on full blast when the car got hot and its to noisy for me so i changed the one behind the headlight and everything now works as it should? I still have a brown plug hanging Share this post Link to post Share on other sites
Baz 421 Posted May 3, 2007 Another vote here for doing away with them, they're crap. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted May 4, 2007 Thats weird, i have a brown plug hanging and another brown plug with a resistor behind the headlight. My fans were coming on full blast when the car got hot and its to noisy for me so i changed the one behind the headlight and everything now works as it should? I still have a brown plug hanging They should be clipped to the rad but replacement rads are always missing the clip for it so you find them stashed in all sorts of places around that area. Not a good idea to leave them loose though as they can melt their way into the wiring loom causing all sorts of damage, this destroyed the alarm that had been fitted to my car when I got it... Rob P.S. Clip is available from Peugeot for not a lot, then just need to pop rivet it on... Share this post Link to post Share on other sites
