chris1986
Can Some One Help With This.oil Sensor
chris1986
i'm not sure if this is the oil pressure/level/temp sensor, but i need a new one as this one has leaked all down my new engine unfortunately i cannot uploads pics just at mo but its the one if you look inbetween the alternator and inlet man there are two sensors, it's the one on the left that i need to know. anyone got a part no and price?
Mikey S
if its the smaller of the 2 mate, its the oil pressure switch. you can get them at your local motor factors for around a fiver. ;)
http://www.stuartmcguire.co.uk/pug/GB/205N/1/11A20L.HTM
Oil pressure switch, Pug Part # 1131 14.
Seal is same as 16mm sump washer.
You should be able to upload to the forum with driver status.
Graham.
