Guest Stu@
Name This Plug..
Guest Stu@
Nearly connected my bx 16v engine up but struggling with the plug that spurs off from the battery terminal..its a big black box and looks like 2 spade terminals connect to it. Can someone please tell me what this is?
Also the fat blue wire that goes to the power distribution block at the slam panel - do i just need to swap the spade for a ring terminal and bolt it to?
No idea about the black box you mention unless its the BX version of the shunt box (power distribution box) but the spade terminal on the fat blue wire should be fitted to on of the spade connections on the shunt box where the original ecu was plugged in.
Graham.
Guest Stu@
cheers for that garaham, hopefully the black box thingy isnt needed!
