clifton 0 Posted April 27, 2007 i had my gearbox swapped over, from a be1 to a be3...and ive put it all back apart from the clutch cable because i dont know to put it back...sounds stupid i know...i had someone look at it but they they said i was missing some rubber thing that goes onto the end of the cable..is this right? if it is what is the part called and does anyone have a part number? this is the clutch cable i have. is it th right one? if it doesnt need this rubber thing how do i fit the cable...pictures would be much appreciated cheers ben Share this post Link to post Share on other sites
welshpug 1,666 Posted April 27, 2007 take a picture of the whole cable if you ca, to me it looks like theres a part missing there. Share this post Link to post Share on other sites
hengti 2 Posted April 27, 2007 to me it looks like theres a part missing there. what's that in Homer's hand? . looks complete to me (?) - Haynes explains how to fit them. Share this post Link to post Share on other sites
Radster 0 Posted April 27, 2007 that is correct for be3 Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 27, 2007 Ben, I'm sure I looked at your cable when I refitted the gearbox & it was all there so it should fit with no problem. There is nothing missing on either end, the end above is complete, as the the pedal end in the picture below; Graham. Share this post Link to post Share on other sites
pug_life 0 Posted April 28, 2007 its more complete than mine, (and mine works).... You swapped pedals over? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 28, 2007 You swapped pedals over? I supplied a Be3 pedal so I guess Ben has by now. Graham. Share this post Link to post Share on other sites
steve@cornwall 100 Posted April 28, 2007 i had my gearbox swapped over, from a be1 to a be3...and ive put it all back apart from the clutch cable because i dont know to put it back...sounds stupid i know...i had someone look at it but they they said i was missing some rubber thing that goes onto the end of the cable..is this right? if it is what is the part called and does anyone have a part number?this is the clutch cable i have. is it th right one? if it doesnt need this rubber thing how do i fit the cable...pictures would be much appreciated cheers ben I guess the confusing bit is the lack of a bracket such as on the be1? the large black piece on the left of your pic pushes into the round bottomed lugs on the gearbox and has a couple of sprung clips in the plastic to locate it Just under the afm Share this post Link to post Share on other sites
clifton 0 Posted April 30, 2007 stil dont have a clue how to do this...does anyone have any pictures of where it should go? ben Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 1, 2007 I've posted a picture of where the outer cable end stop fits into the gearbox before here. The plastic bung by the adjusting nuts fits into the clutch arm. If you can't figure it out from this let me know & I could call round on Friday evening to show you / fit it into the gearbox. Have you done the pedal yet? Graham. Share this post Link to post Share on other sites
Alastairh 47 Posted May 1, 2007 Looks complete to me Share this post Link to post Share on other sites
