rex
Brembo Brakes....
rex
Hi everyone,
Yeah - Brembo brakes off a 406 coupe - well, they're on with my home made wheel spacers and Xantia discs which I still haven't had tome to drill....(thanks Hilgert :D )
I was wondering (as the engine isn't in there yet) whether people running this mod have changed master cylinder - I remember driving a Mi16 205 with GTI-6 brakes that had mega travel in the brake pedal - will I suffer the same syndrome?
I'm thinking about changing it anyway as it looks as if it is going to foul on the 605 turbo engine that's replacing the old 1.9 lump.
Any thoughts, as usual, will be greatly appreciated.
Regards,
Rex
Edited by rex
Hilgie
I used the mastercylinder off a 406 (pre 1998 model). Which has a 23.8mm one with straight connections.
I think the braking will be useless with the standard one (too much fluid travel to fill the 4 pistons).
rex
Thanks again Hilgert. Again :D
Will this be shorter in length?
Externally the master cylinder is the same length as the 20.9mm standard GTi one within a few mm's.
Jrod
Also using a 406 master cylinder. :(
Edited by Jrod
rex
Thanks Graham.
