lee7421
Rear Speakers
lee7421
hey all not long bought my new 205 :D its got 6x9s in the rear at the moment but i have bought a new shelf without holes. Problem is i still want sound in the rear of the car! What size are the origional speaker holes? and do speakers sound ok situated here? cheers guys! :)
Jrod
13cm.
I think a decent set of 13cm's is good enough, depends what your after though.
lee7421
cheers mate so i aint gunna get any nasty vibrations if i put some decent speakers here? :(
DrSarty
Hmmm, you shouldn't be expecting too much from ANY speakers in there, no matter how expensive. The reason is a 13cm speaker in a rather flimsy metal mount which is not really acoustically sealed front to back, is never going to produce sufficient bass to produce any vibrations or rattles.
Ideally those speakers are just to raise the sound stage a little in conjunction with the fronts (and give rear passengers some music I suppose) and will not compete in anyway with what was produced by the 6x9's just removed. Also ideally if they were/are powered by an external amplifier, you'd not feed these little speakers (bless 'em ;) ) with much, if anything below 80hz or maybe 100-120hz. Doing this and having even a diddy sub in the boot will make a massive difference if decent sound is what you're after.
Not wanting to get technical, but just don't expect too much.
Rich :)
lee7421
cheers for that mate. im putting in a sub an have front speakers an jus thought people in the back would just hear bass an nothin else so it is kind of 2 add some sound in the rear
Guest Puddlez
just wondering if you managed to get anything good for your rear speakers? I got some alpine type e 13cm coax speakers to replace my rear speakers but actually wiring in my head unit i found my rears were awesome as they were. Im using the aplines in the front now and they sound great considering theyre only type E's and cost £30 :ph34r: Also a 10" JL or such like in the boot would provide tons more bass then any 6x9 would and looks/sounds much cleaner.
