Kenno 3 2 Cars Posted April 25, 2007 Hiya, I was left with a members 205 over the wknd due to someone fitting the wrong cooling distribution block fitted to the bottom of the steel block of a s16so is belived!! the xu9 alloy 1s that I have lying round are too small too as the dia out of the block is around 40mm n the xu9 is 35ish all help needed please as I need to sort his car asap so he can pick it up from my street. Cheers Ps its made of plastic & has the main rad outlet plus 3 smaller outlets. Share this post Link to post Share on other sites
welshpug 1,657 Posted April 25, 2007 doesnt it use the same part as the 2.0 405? if so... XU10J4 1336 C1 WATER INTK TANK 1339 83 TANK GASKET DIAM 42 C001 RUBBER Share this post Link to post Share on other sites
Kenno 3 2 Cars Posted April 25, 2007 yer cheers bud your rite. Share this post Link to post Share on other sites
