Richie-Van-GTi
Xu10 J4r Cams
Richie-Van-GTi
Im picking up an xu10j4r 135bhp engine this week from a fellow member, what other cams fit this lump? Can I stick MI cams in etc?
thanks
mi cams wont fit, J4RS cams will :rolleyes:
PsychoSimon
you can get the standard cams reground to a bigger spec than standard gti-6 cams and other than that the gti-6 ones are the best bet
As said only the J4R or RS cam;s fit, I;ve got a set of 6 cam's I don;t need if any use
Or I can regrind your J4R inlet to something even more interesting!
Richie-Van-GTi
Miles and peter, prices please :o
Im not in any rush to fit the engine as Ive just built the current engine to spec below so I want to build this one in spare time to a real good spec then run it on carbs with mapped ignition. Just as well as moneys a bit tight.
Mattsav
Or you start with new blanks and have something far more interesting :o
Richie-Van-GTi
sounds expensive, out of interest how wild can I go on OEM valves etc? Not too worried about idle it can be as lumpy as it likes, i prefer the sound of lumpy idles anyway.
Also a side note, could I modify my existing 4 branch to fit the other engine?
chris 417 mi
guess you got that engine you were on about then :)
GTi6 cams are basically identical to 1.9L Mi16 cams, so that gives you a starting point. I could do my Stage I or Stage II profiles on the original cam, but that would be the limit. To be honest, my Stage I profile would be the best option. It can make up to 200hp on a 2L engine. The Stage II is obviously bigger, but requires ignition mapping and more CR to get the best out of it.
Richie-Van-GTi
Ive created a new thread peter, I would really appreciate your advice in there as you will see exactly what my plan is.
