Radster 0 Posted April 23, 2007 The only thing im not sure about is what ECU I have! I bought the whole lot, AFM, ECU and loom off ebay and it had apparently come from a 405 Mi16, however when we got it there was quite a bit of 8v stuff spliced into it? Needless to say the car starts, idles and runs just fine, we did an emissions test and that was all ok also, the problem I have is that when I plug the ICV in with what I assume is the correct plug the revs hunt all over the job, Im also not 100% sure which connection is for the knock sensor The end code on the ECU is 162 which after searching through the forum seems to come back as a 205 16v cat? Could this be right? The only thing I know at the moment is it runs fine and pulls well (upto 4k obviously) with no untoward noises or anything like that and all the guages appear to be working correctly. Could someone confirm that the ECU 162 isnt from an Mi16? Regards, Adam Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 24, 2007 Whats the full ecu number? Ending in 162 does point to it possibly being from a cat 1.9 8v; 309 GTi 1.9 litre 8 Valve 88-91 Bosch Motronic 1.3 0 261 200 162 All the ones I can find listed for an Mi16 are; BX GTi 1.9 litre 16 Valve 87-89 Bosch Motronic ML4.1 0 261 200 119 BX GTi 1.9 litre 16 Valve 89-90 Bosch Motronic ML4.1 0 261 200 140 BX GTi 1.9 litre 16 Valve 90-93 Bosch Motronic 1.3 0 261 200 354 309 GTi 1.9 litre 16 Valve 89-90 Bosch Motronic ML4 0 261 200 139 309 GTi 1.9 litre 16 Valve 90-93 Bosch Motronic 1.3 0 261 200 354 309 1.9 litre 16 Valve Cat 90-93 Bosch Motronic 1.3 0 261 200 161 309 GTi 1.9 litre 16 Valve Cat 90-94 Bosch Motronic 1.3 0 261 200 529 405 Mi16 1.9 litre 16 Valve 87-89 Bosch Motronic ML4 0 261 200 125 405 Mi16 1.9 litre 16 Valve 88-90 Bosch Motronic ML4 0 261 200 139 405 Mi16 1.9 litre 16 Valve Cat 88-92 Bosch Motronic 1.3 0 261 200 161 405 Mi16 1.9 litre 16 Valve 90-93 Bosch Motronic 1.3 0 261 200 355 Graham. Share this post Link to post Share on other sites
welshpug 1,677 Posted April 24, 2007 I couldnt find any ending in 162 on the site I usually check part numbers on, not for a epugeot anyway. I did however on a Citroen get this - BX 1.9 litre 8 Valve Cat 88-91 Bosch Motronic 1.3 0 261 200 162 Share this post Link to post Share on other sites
Radster 0 Posted April 24, 2007 (edited) 0 261 200 162 Bah, its a 3 row ECU if that makes any difference (I assume it is as it has 3 rows of connections on it), although I guess 1.3 relates to this, im not too hot on the electrical side of things Edited April 24, 2007 by Radster Share this post Link to post Share on other sites
welshpug 1,677 Posted April 24, 2007 well from what I found and what Graham said I'd go with the fact that you've been sold an 8v ecu so It wont have the 6850 odd rpm 16v rev limit, but the 6200 rpm limit. DOH! Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 24, 2007 309 GTi 1.9 litre 8 Valve 88-91 Bosch Motronic 1.3 0 261 200 162 BX 1.9 litre 8 Valve Cat 88-91 Bosch Motronic 1.3 0 261 200 162 0 261 200 162 Looks like you've been sold a duffer. Graham. Share this post Link to post Share on other sites
Radster 0 Posted April 24, 2007 Bugger, I guess the problem I have now it that if I get hold of a 16v ECU I may not have the knock sensor or ICV connections in the loom The AFM is Mi16 though Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 24, 2007 What colour & how many pins are on the plug you've been trying to plug into the icv? Although plug colour isn't a certainty there should be two pins iirc & if you have a mulitmeter you can check if the loom is right or not at the ecu plug between one of these pins. Pin 4 on the ecu plug should ring out with one of them but if the loom is also from the 8v cat it won't have had an ICV. Graham. Share this post Link to post Share on other sites
Mikey G 3 Posted April 24, 2007 In This Thread i posted a list from my computer in my chip files that sugests there was a 16v 205 with this ECU. I also have the number 1267355643 which is listed in the BX19 ECU If you can take the top off the ECU and take a look at the number on the eprom, if it matches the number on the 8v one i may be able to send you a standard file for the so called 16v version if you want to give it a try, and if you know someone local who can reprogram your eprom. Share this post Link to post Share on other sites
Radster 0 Posted April 24, 2007 The loom has a brown multiplug thing on it so its definately partially 8v Im not sure whether any of it is 16v stuff, I assume some of it is, could be two looms spliced into one but im beginning to think it isnt even that, I guess ill have to cut my losses and buy another lot, least I can sell this as people may want Motronic. There are two plugs ive tried but they just make it hunt for revs Share this post Link to post Share on other sites
Radster 0 Posted April 24, 2007 Right, sourced myself a mi loom, AFM and ECU thanks for all your help Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 25, 2007 In This Thread i posted a list from my computer in my chip files that sugests there was a 16v 205 with this ECU. Where did you source this list from? There was never a factory made 205 with a 16v engine afaik! Graham. Share this post Link to post Share on other sites
Mikey G 3 Posted April 25, 2007 Where did you source this list from? There was never a factory made 205 with a 16v engine afaik! Graham. I just acquired it I know there was never one made but it has appeared from somewhere, it is in my list of chip tuning files i have from most cars upto around 1997. Even though the ECU ends in 162 the chip itself has a different code to the 2 8v units also listed with this ECU sugesting it is mapped for another engine. Share this post Link to post Share on other sites
