Dan Ingram 1 Posted April 22, 2007 I picked up my new 205 a couple of weeks ago. It hasnt been pulling quite as well as my last one from day one. I advanced the timing slightly which helped but upped the idle speed so I turned that down and it idles spot on. It pulls well to about 4k but then starts to hesitate through the rest of the rev range so I replaced the ignition module as after doing a search that seemed like the most obvious problem. It hasnt hepled Does anyone have any ideas that I could try?? Im going to replace the coolent temp sensor as its not exactly expensive but im not sure if that would be a cause of the problem. Would retracking the AFM help at all or does that just help with idling issues?? Another possibilty is the leads and plugs but they look to be ok. Would blocked injectors be anything to do with it?? I have no idea if they are or not im just trying to think of anything that would cause the problem. All help would be greatly appreciated on this matter as its annoying me Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 23, 2007 Have you checked the distributor cap condition? Although this usually effects things more at lower rpm imo if it hasd bad tracking on the pick ups this could be part of the problem. Have you tried adjusting the timing again to see if it cures or improves it? Graham. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted April 23, 2007 Doubt ignition timing will cure hesitation - sounds like a poor spark for whatever reason. AFAIK there is no easy way of telling where though so it would be check the usual suspects time. E.g. leads, dizzy cap and rotor, coil and ignition amp (which it sounds like you have tried already) Rob Share this post Link to post Share on other sites
Richie-Van-GTi 74 2 Cars Posted April 23, 2007 whip the plugs out after a run and check the colour, possibly low fuel pressure and its running a little lean top end. Share this post Link to post Share on other sites
Guest Puddlez Posted April 23, 2007 My GTI did this when i got it first! Would get to around 4k and not want to rev any more! Found out in the end that it was the Throttle cable! There is a Cam on the Throttle Body that the Throttle cable sits on, it had fallen off this! Put it back on and i've now got full throttle again and it revs lovely Worth a look? Share this post Link to post Share on other sites
boombang 2 Posted April 23, 2007 Have you checked the WOT throttle function of the throttle switch? Share this post Link to post Share on other sites
Dan Ingram 1 Posted April 23, 2007 Not really sure how the T.P.S works or how it should be set. Does it have a position for full throttle and idle?? Share this post Link to post Share on other sites
boombang 2 Posted April 23, 2007 Aye it does. Can't recall which pin is which but there are only 3 pins IIRC so a few seconds with a multimeter and it should be pretty obvious. Pretty sure my current 205 WOT sensor isn't working just haven't got round to testing it yet. Share this post Link to post Share on other sites
Dan Ingram 1 Posted April 23, 2007 Thanks for that i'll have a look. I take it that if the tps isnt set to know its at full throttle then the ecu dosnt allow enough fuel? I suppose that would make sense Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 24, 2007 Have a search, I know I've posted the test prcedure for the TPS before. Its a simple open & closed switch, closed at idle & WOT, open inbetween. Graham. Share this post Link to post Share on other sites
