Gavin Waddell 18 Posted April 22, 2007 was wndering if any one had a photo of how the bracket that holds the ecu is fixed. ive had a look but with my head upside down its a bit hard. cheers gavin Share this post Link to post Share on other sites
inferno 1 Posted April 22, 2007 (edited) it has three, 6 or 8 mm bolts/nuts holding it up. quite tricky to get to sometimes. Edited April 22, 2007 by inferno Share this post Link to post Share on other sites
Gavin Waddell 18 Posted April 22, 2007 chers inferno, but what i need is a photo to see which way round it goes Share this post Link to post Share on other sites
Baz 421 Posted April 22, 2007 How the bracket itself is fixed? that's your question anyhow so... There is one of those star washers holding it, then a bracket that goes upwards and is held in by the dash bolt, to get it out you have to take off the washer, then undo the dash - 10mm under scuttle panel each side, one 10mm bolt in centre of dash, behind triangular panel above ashtray, and one behind heater vent on each side,) and pull the whole dash through the hole in the bulk head on the driver's side, so the ecu bracket will become free from the bolt itself. Did it myself yesterday to remove a wiring loom, PITA!!! Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted April 23, 2007 The standard ecu mounting tray will only fit in one way. Graham. Share this post Link to post Share on other sites
Gavin Waddell 18 Posted April 23, 2007 i no it only goes in one way but which way is the question. baz will have a look at it tomorrow, i only have half a dash its a track car, so i might jury rig it. Share this post Link to post Share on other sites
