justinv 4 1 Cars Posted April 21, 2007 Removed D 701 from my ecu still no revs over 6000 !!!! anything else one could do? tried it on both a 1.6 and a 1.9 ecu Share this post Link to post Share on other sites
Mikey G 3 Posted April 22, 2007 Did you desolder it and remove it completely or just the one end and lifted it? I normally remove the link B34 next to it by snipping it, i'm wondering if you desoldered it did you spill some solder underneath over to the connector in that link? This could cause a short so it still makes a circuit. Share this post Link to post Share on other sites
justinv 4 1 Cars Posted April 22, 2007 ok i will try that aswell but could a ba timed engine still make this cause mine is a bit messed up at the moment? Share this post Link to post Share on other sites
Mikey G 3 Posted April 23, 2007 Did the engine reach the rev limiter before you decided to remove it? If not i would get the engine sorted and make sure it is running fine before trying to rev the thing past its limiter. Share this post Link to post Share on other sites
