Pete C
Really Bad Jerkiness
Pete C
A mate has just finished rebuilding the engine on his 1988 1.9 GTI. It has an XU10 head with the 1.9 cam, a lightened and balanced bottom end and a lightened flywheel, also an adjustable FPR. Everything else is standard bar an induction kit (which hardly counts) :o
However, he's getting really bad jerkiness at low speeds, and even at higher speeds when descending hills on the overrun, for example. It's not the normal jerkiness, he and I have owned no less than 7 205/309s between us over the years so we know what that's like! :D
It's similar to the normal type of thing, just much worse. So far we have tried:
Adjusting TPS
Advancing ignition timing
Different AFM
All to no avail. I'm not saying it isn't one of the above things, but we have tried :)
Any suggestions?
Edited by Pete C
GLPoomobile
This may not be relevant as yours is a modified engine, but I have the same on my XU5 after swapping the head.
In my circumstances I suspect the most likely cause is the cam timing possibly being out by a tooth. It was the first time I'd done a job like this and really struggled fitting the timing belt so reckon it's the most likely answer.
dump that FSE thing for a start, see what its like then.
DrSarty
Just an idea: a leak somewhere allowing extra air in, perhaps just after the AFM. Split trunk, loose jube clip?
I hope it's that simple dude; must be really annoying.
Rich
Grim.Badger
I'd agree with Dr S on this one, it's probably a big air leak.
Check the usual suspects first like the bolt holes on the inlet manifold but air can get in anywhere, even the oil breather system and injectors can leak air.
What colour are the plugs?
lagonda
Jerkiness on mine happened when I unscrewed throttle stop screw to reduce high idle resulting from timing changes. This stopped TPS operating correctly. Now everything is now more or less correctly set, jerkiness has gone, so I'd check TPS for correct setting & operation.
